Hai, i am new here.. im looking for some advise for stage 1 mod(what to install) on my caldina gt-four..if im not mistaken, it was the 4th gen 3sgte engine...
im also wondering about the mod...what thing are need to be done for the 1st , 2nd and 3rd stage mod and how much increase/gain in hp after each stage.
btw,i've insatlled trust back dcat, apexi intake system/air filter, turbosmart boost controller and trust blow off valve..
  • 3 months later...
nice. a caldena gt4, sorry im not here to give adivice,
but i would like to know if you have any pictures of your gt-4
good quality induction kit, then an exhaust (possibly need one custom making) then an electronic boost controller and set to 1.1bar. should see lively performance. as your car has an air to air intercooler thats mounted on top of the engine i would recommend either an ERL water injection system or if funds allow a front mount intercooler
is this the NA block (VVTi) or the blown block (turbo'ed).
for basic tuning it's all about getting cold air in easy and hot air out fast.
So cold air ducting and de-catted exhausts.
Then for NA, you have to look at cams, timing or TB's
For turbo, wind the boost up and then look at FMIC's and WI etc ..
and a good aftermarket ECU will help a lot.
  • 5 months later...
Hai mate..
Seen im new here,can you tell me more about the ERL water injector and its function? hehe what can it offer to my cald? and what size should i use for full exhaust system from down pipe till back dcat? btw,can u guys help me how i can post a pic here?
Hi Bibbs,
The Caldina GT4 has the 3s-gte engine, and it hasa turbo with 260 hp and about 320 Nm in torque.
I started a similar mod project on a 2003 gt-4 calidna ACE
I starting with a Water injection kit...either ERL aquamist or snowperformance.net's boostcooler 2 system. You can follow the post here as I am documenting it
http://www.wheelsjamaica.com/wheels_forum/...p?topic=53305.0
I need ideas as what mods to do or mods that I can possible do
  • 2 months later...
Hey dude,
Nice wheels mate. Sign of good taste if I may say so. Got one just like it. Keep up with ur posts, I'm curious as to what u'll achieve with ur cooling project.
I'm done with the styling bits for now, so it's off to the tuner we go!
