Lucida Radio
foggie
Pull out the slideout cupholders and the front basicly can be pulled out. :thumbsup:
From memory I had to prise(sp?) off the surround being careful not to damage the console then it all became apparent as the radio is held in by a cage (unlike most makes) which is secured by 4 screws which can be seen once you have the surround off. As Leeky said you need to remove the cupholders first. :thumbsup:
