i no longer have the previa,i now have the lucida and i need to take the radio out to put an expander on ,i have no idea how to take it out.
You need to remove the cup holder and prise(sp) off the surround which is just clipped in place.
With the surround removed (be careful not to damage the console) you should see set quite far back 4 screws, 2 either side, which hold the bracket in place.
Remove the stereo and bracket as the stereo is screwed to the bracket and difficult to seperate the 2 until you have the whole thing out.
Hope that makes sense. Once the surround is removed you will see what i mean. :thumbsup:
