Supra Mkiv Not Starting
RAZ492
Let me tell you the basics of the problem :-
I have a Supra Twin Turbo uk-car on a 96-N, recently the car has been parked up and not been used, hence the Battery died and even though the ignition came on it wouldn't start.
I recharged the Battery and the alarm worked again and i blipped it on and off and the car fired up, HEY PRESTO.
So i left it for a few weeks again without firing it over (DOH) and the same happened again, but this time after charging it for 2 days and the alarm wont switch off ie. the immobiliser wont turn off and the car wont start up !!!!!!
I dont understand as the last time it happened and after a quick charge it was fine but this time the alarm wont respond. WHAT SHALL I DO ??????
Any suggestions gratefully accepted.
Raz :crybaby:
Raz,
had the exact same problem with my black N reg UK car,
not used for a couple of weeks and the Battery died which made the alarm play up..
if your car has the original factory alarm (Black Fob) then i think the only way around that will be to bypass the alrm/immobiliser.
BUT first try replacing bvattery in the fob and press both the red/black buttonfor about 15 seconds together which may help the alarm re-set itself.
Rash.
Raz,
not used for a couple of weeks and the battery died which made the alarm play up..
Rash.
Its the genuine alarm, i tried the spare fob, looks like new, no joy, tried holding the two buttons together and no joy too :-(
Have tried most things in the post you just showed me, gonna get a mate to look at it tomorrow. !Removed! ****** me off.
Cheers anyway bro :thumbsup:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
