hi all,
i have a 1994 cynos b 1.5 for 2 months now and know sweet F.A bout them,anyone know the engine spec for them?bhp? i heard i could bolt the turbo from a starlet straight on,and ecu and looms...is this true?
you can turbocharge the 5e but its hardly a bolt on option
Unless you want a big project the 4e-fte engine swap is the best option - although this itself isn't straightforward.
the cynos will have either the 5e-fhe or the 5e-fe engine which is 100 - 110bhp
the 4e-fte turbo is only a 1.3 compared to a 1.5, but is 133bhp as standard and will tune further.
ive the 5efhe engine,so it wouldnt be a simple job then:(
to turbocharge the 5e-fhe you would need:
4e-fte or better injectors
4e-fte or better exhaust manifold
4e-fte or better turbo
4e-fte or better thermostat housing
4e-fte or better oil filter housing
4e-fte or better sump
4e-fte or better turbo oil and water feed lines
4e-fte or better turbo dump pipe
4e-fte or better ecu
4e-fte or better map sensor
4e-fte or better pistons (lower compression ratio)
better clutch
intercooler
the 4e-fte swap is probably easier.
As it stands the compression ratio of the 5e-fhe is too high to be turbocharged safely. You can bolt the turbocharger on, but something is going to break sooner rather than later.
thanx for the info mate,i tink i'll go for the engine swap,seems to be the easiest option
better clutch
intercooler
