First Moves On Acquiring A Grey 4dr Yaris
flashman
Hi folks;
I am a Saab driver who just acquired a light grey automatic
Yaris for delivery by end-December in Calgary, Alberta, Canada,
just out here by the Rocky Mountains.
I am swapping out the mfg's tires for Nokian WR's immediately.
As this will probably be a city car only, the tire guy says "use
14" rims". Any other advices and opinions, gladly entertained.
First priority:
I need to get some Canadian Tire wet-catcher rubber mats for
the odd day here your car's floor catches a lot of grit and maybe
clay particulate matter, not to mention the moisture that carries it
in there.
Biggest beef: no sunroof
Second biggest beef: no side airbag option
My 21-y/o owns a 1998 Subaru Legacy GT and is also getting Nokians.
With a 100K km tire wear warranty, how can you go wrong?
Never heard of any of those brands you talked about
but welcome to the club mate :D
Thanks very much. Nice to be here. Top 'o the
Season to you. :D
I cannot fault you for not knowing Nokian except
perhaps by its mobile telephones. Nokian also
produces what us sometimes challenging winter
climes drivers regard as the supreme winter tire
- a tire I had on my 1st Saab and on a Mitsubishi
Mirage turbo on separate rims; the Hakkapeliitta.
(no financial interest)
Canadian Tire is a very popular and successful
Canada-wide franchise operation and one of the
very first retailers to deploy computerized inventory
controls back in the 20th Century.
(also, no financial interest)
I'm afraid all this winter preparation may be premature
and feeling now like not even needed this year. We're
headed for a warm, dry, 'brown' Christmas again. Record
for Christmas here is about 21C. We look like getting 10C
Sunday in what is known as a 'Chinook;' a wind like the
Mistral named for its capability to 'eat snow. In fact, in
the aboriginal language, 'Chinook' means 'snow-eater.'
...automatic Yaris for delivery by end-December in Calgary....
...Any other advices and opinions, gladly entertained.
I need to get some Canadian Tire wet-catcher rubber mats...
...Nokians [tyres].  With a 100K km tire wear warranty, how can you go wrong?
Custom molded fit and colour coded Toyota mud flaps
http://makeashorterlink.com/?E27D2545C
The car already has holes for these flaps. If some run-of-the-mill generic rubber flaps are to be fitted instead, probably holes need to be drilled into the wheel arches, not a desirable practice in terms of integrity of the factory provided overall anti-rust protection.
Seeing Calgary is not unusual to be around -30ºC in winter (OK, not now but we'll see. :)), and has heavy snowfalls in early spring, I can't think of an accessory more desirable than a PRE-HEATER. These two in the links below are not Toyota accessories it has to be said. I don't know much about the more expensive Webasto unit, but the Kenlowe modules can be easily taken out and put in your next car without problem.
Webasto Heater
http://www.webasto.co.uk/am/en/am_automobile_3177.html
Kenlowe Heater
http://www.kenlowe.com/pre-heaters/cars/whatwill.html
Have fun with your new Yaris.
Bee.
Hi Bee;
What excellent suggestions, tyvm :)
My wife cannot be relied upon to plug in the Saab
and I fear we have lost engine life and possibly the
rear cat because of it. I know she is hurting on
gas mileage from startup as she is now averaging
13.5 l/100km whereas before, we had been getting 12.5,
worst. This is all-city driving at 7 miles to and 7 miles
from work, stop-n-go. Perhaps the O2 sensor has seen
better times.
I was impressed that the Kenlowe was used on F1 and WRC
cars and shocked at the replacement cost of the 1st Saab
block heater, a crude device which has seen no technological
advancement in many years and is (or had been) universally
fit out all cars sold in Canada.
Are you sure the ECHO mudflaps will fit the Yaris? I will
price and compare the dealer models in the meantime.
Thanks again for the reminder.
My first Saab, a '79 900T, came with three (3) sets of mudflaps
making the car look more like Darth Vader than you can
imagine. The underside flaps prevented gravel deterioration
on the underside brake parts, suspension etc. This dark blue
car was a true Dukes of Hazard foothills-mobile on gravel roads
back and forth to the gas plants. In winter, it was equipped with
Nokian Hakkapeliittas, said to be the best snow tire in the world.
These tires are so good, I bought a set for my second turbocharged
car - a Mitsubishi Mirage under the Dodge Colt nameplate (also 106
hp).
The '99 Saab came with only one set of flaps - on the front wheels.
There has been no call for rear flaps.
From what I have read, I am sure to enjoy the Yaris. In computer
use, I am an early adapter and even in Canada, Saabs are
still looked upon as a bit of a curiosity. I'm sure it will be the same
with the Yaris for a bit and I will enjoy that.
Cheers;
flashman
Hi and welcome!
For those of us who don't know, Nokian seem to be a very highly regarded winter tyre in North America.
Were I replacing my Yaris with a new one I would probably just keep the 14" steels I use for winter instead of the 15" whells that will be standard here. I don't know about Canada, but here you are supposed to keep your speedo within a certain %-age of "correct" so unless you want to re-calibrate your speedo twice a year its worth making sure there's not going to be too much of a change in rolling radius (there's a calulator thingy on this page if you want to check)
Hope that helps!
Alan
edit: PS If you think your Yaris will be a curiosity then that's nothing compared to how weird the diesel and 1.0 litre versions would seem to many!
PPS You do know that the lines of text wrap and you don't have to press return at the end of each line, don't you? :unsure:
Very helpful and informative, yes, Alan, thanks.
......... "just keep the 14" steels I use for winter "
That's the plan, yes, except that the Nokians I bought are all-seasons. The best all seasons money can buy, or so I'm informed.
.... diesel
Canada's diesel refineries are not up to European standards. We don't get a broad array of diesel engine choices.
..........press return at the end of each line, don't you?
Firefox does have its differences. I'll give it a try.
Cheers
Aha! Well, if they're all-seasons then I'd be inclined to get whatever is the original size to start off with (I see that Canada get both 14" and 15" depending on spec...) and then work from there...
As I said, I've also heard good things about them.
I hear about the diesel "problem" regularly on other forums - mainly from people sick of their VWs and don't want/need a Sprinter!
I use Firefox too (1.5, but previous versions were fine too...)
Before I turned to Yaris, I'd been doing homework on running costs of small cars through Edmunds. I was shocked to find that the VW Golf diesel was no more cost-efficient than a few of the others, including the ECHO. It was at that point I became interested in Yaris. Handling and reliability were considerations. The VW was way too expensive for what you get.
US refineries are setting up to accept EU diesel standards. Lucky them. Canadian refiners have yet to get the high sign on the necessary mods.
Webasto Heater
Kenlowe Heater
Bee.
Bee: The car came with mud flaps; nice ones. In the end, I bought
red (my first red car, ever) and I/we love it. The dog needs to
learn to jump higher into the back seat. She flubbed her first
attempt, thinking the seats were like the Saab's back seat.
I got the floor mats (Michelin built and engineered) in a clay
color, as that is the color of our earth here and dirt won't show
as badly.
I hope the Yaris has as good a cabin air-clearing system as Saab,
considered an industry leader in HVAC for cars and you get used
to the quality.
My tire guy sold me a set of brushed alumnum-colored 7-spoke wheels
for the Bridgestones and called them a 3-season tire whereas
Nokian WRs are true 4-season tires. (with a 100k all-in warranty).
My Nokian WRs go on the plain-Jane steel rims and when the really cold
weather comes, the plastic wheel covers come off and the black wheels
are exposed for action.
Subaru WRX people watch out, here I come. I am a seasoned and
fearless winter road warrior having piloted 2 TurboSaabs faultlessly
and quickly through many icy winters on Michelin Alpins and Nokia
Hakkapeliittas. These latter tires were mounted on gorgeous gold
and polished aluminum multi-spoked wheels for the Dodge Colt Turbo
I drove for about 6 years, incidentally during the Calgary Winter Olympics.
I ran your item covering for engine-heating upgrade from the UK (2) past
the Saab people. On balance, the contributors felt (one having owned a
Kenlowe) that these heaters are superb additions to a cold weather car.
Thank you for bringing that to our attention.
Merry Christmas and Happy Hogmanay! :thumbsup:
