Size
big_bad_ant
Hello,
has any one here changed their front spreakers in their 97-00 rolla? if have, what size is it?
:thumbsup:
Never done it myself, but I seem to remember reading that its a bit of a pain in the ****, as the existing Speakers are riveted into the door, thus requiring some 'reverse engineering' to fit new ones :)
I just got a drill and drilled the rivets out then did a bit of custom work for the speaker surround so it would stay in place and then screwed it in. Worth doing!
cheers for the help lads but what is the size of it?? :thumbsup:
i replaced my fronts when i got my g6r a few years ago. You do have to dril the rivets out as they are riveted directly to the door frame. You can use self tapper screws for your new ones.
If I remeber correctly the originals are 10cm / 4 inch but i squeezed in 13cm jobs.
Pioneer etc used to have parts of their sites that told you what size Speakers each car takes but I can't find them. I'll keep looking but if you are really stuck I'll pull my door trim off and have a look for you. Don't what you buying them and being wrong.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
