Rear Number Plate Lights
viperroom_112
Hey Guys , once again I am stuck ...
Well one of my number plate lights went out last week , so I changed it ! When I changed them I used some blue LED lights whixh work really well , but it appears that both bulbs are slanted to the drivers side . :wacko:
Is this normal ? As i thought one bulb faced the drivers side and one faced the passenger side ? ?
Hope you understand what I am saying ? ?
Thanks DM
Life will be less complicated if you stick to the manufacturer's recommendation: 5 Watts D type (i.e. push fit) bulb. :)
Now, the socket being a push fit contact, can you not rotate the blue (!) LCD in its socket to direct the beam onto the centre of number plate correctly?
Bee.
Bee.
As above -
Make sure you have put the unit back in properly and that your not standing on a slanting surface ..... however im sure the light should still cover the plate
*post a pic?
But im sure they wont be in long - until Mr Plod spots you (unless you have different laws up there :unsure: ?)
