Suspension Knock - Safe?
Leeky
I've been driving around with the same offside front knocking sound for months. Was told it's extremely dangerous!
It's going in my local Toyota World tomorrow and it's costing £450 to fix.
!Removed! expensive this Celica lark :!Removed!:
i really dont know why the even put superstrut on the 202's , left over parts most likely , the 202 dont really need it . IMHO
one things for sure once its done = no more knocking for 60 to 70 k mate.
just out of interest what are they changing for £450
I assume yours is an import then :)
lee if you get stuck , it will be with 1 bolt , it dont clear the sump , either loosen the 3 or 4 sub frame bolts and lever it down till you get the bolt out , or you can jack up the engine so i am told ?
i had the knock , cured mine instantly. :yes::thumbsup:
Aha - so that's what the knocking noise is !! I tried about 5 or 6 ST185 CS before buying my present one, and they ALL had a knocking noise from the front suspension............
...........and now, 5 years later, mine has started, :crybaby: (although only a slight knock at the mo and with 66k on the clock !).
Nah will be somthing else on yours, the st185 doesnt have superstrut suspension :thumbsup:
Yeah... We got sensible old skool McPhersons. :yes:
Some of the figures i`ve seen bandied about for geting the supestrut sorted would reduce me to tears. :crybaby:
So maybe its the McPhersons then - cheaper ?, he says hopefully ! :unsure:
alot lot cheaper mate
Front - Pressurized Gas Shock Absorbers KYB £58 EACH :crybaby:
Rear - Pressurized Gas Shock Absorbers KYB £70 EACH :crybaby:
i hope your knock has gone then , nothing on the bill for superstrut parts.
