Central Locking
olly49
Hi to all
I have read all the suggestions on this problem, I to have the problem with the central locking not working.
I have checked all the fuses(will check again) but found none of them blown the interior light does not work however when I slide the switch across to all ways on the interior light works - are there 2 in there?
Keyfobs work the alarm but not the central locking.
Door switch inside does not operate.
Can anyone suggest anything else.
Regards
olly49
Are you saying when you open the door(s) the interior light doesn't work?
Is the door open warning light on the dash illuminate when you open the door?
I think you need to check all the door switches.... if these ain't working right then it will stop the central locking working.....
My works van is like this..... one of the rear sliding doors needs to be slamed shut before the central locking works from the keyfob.
Hi To all
When I put the key in the lock it still will not operate the locks (only locks the drivers door).
Interior light works in On mode, and not in door mode when door is opened.
7.5 amp dome fuse changed still does not operate.
Anyone have any more ideas?
Regards
olly49
