3s-ge Engine
paseoGT4
I have a descent complete 3s-ge engine out of a gen4, Im thinking of getting a car with a blow engine and sticking it in, Is their any difference in the block and head across the gen4, 5 and 6 or even mr2. I know the ancilaries around it will be different but Id use them off the original car. Thanks in advance.
Pretty sure the block and the head are quite different.
The Rev3 has additional oil sprayers if i remember correctly and a slightly bigger sump.
Also the heads are deffo different, the Rev3 has bigger exhaust ports ;)
the altezza black top is designed for front/rear configuration
Does the altezza use the 3s-ge as well then???
