Can somebody help me out removing a stereo from my 1992 paseo that only has 38,000 miles on it (I just got it :-D)
I I think I must remove the whole center plate thing off....and all I see is two screws on each side. I take them out and it still doesn't want to budge...
yup - remove the center console with the rear windscreen heater switch.
there are infact 4 screws holding down the stereo - 2 higher & farther forward then 2 below those slightly further back.
unscrew those & the stereo should pop out.
J
I can't get the front cover off that's blocking the stereo...I see two screws and I take those out and still doesn't want to budge. What did I miss? Is it the heater switch that's holding it?
Your should beable to pry the consol part off with a flat blade - disconnect the heater switch.
I'll try & post some pics up when i've stopped freezing....
J
J
Figured it out. Thanx. I'll post pics soon.
