Central Locking
olly49
Hi To all
When I put the key in the lock it still will not operate the locks (only locks the drivers door).
Interior light works in On mode, and not in door mode when door is opened.
7.5 amp dome fuse changed still does not operate.
All door switches operate ( light on dash etc)
I am able to activate the alarm but not the central locking.
Switch inside does not work as well.
Anyone have more ideas?
Regards
olly49
Hi To all
Regards
olly49
Sounds like your door ajar switch to me.
Does your Dome light work off all other doors? If so, remove your door switch & check it out for corrosion/connection.
If all other doors do not operate the lamp, I will need some more info. Year, spec, engine, fitted woth alarm etc........
Hi To all
Regards
olly49
All door switches operate the light on the dash - the dome light(interior light does not work)except when I press the remote, to switch the alarm off.
Hope this helps.
Regards
olly49
