Parcel Shelf
awol234
Has anyone made their own parcel shelf from MDF or another wood. I want to put Speakers on the parcel shelf and dont want to cut the standard one. Apart from making one, are there any other options.
When making one from MDF what width of wood should i use??
All help greatly appreciated!
alright mate. ive made 6 yaris shelfs for mates and various toc members. its pretty easy to do. get some 18mm MDF and draw round your original shelf. cut the holes in the shelf and place the shelf in your boot and close the lid. get in the back of the car and open the seats and draw round the pegs which the shelf and hinge on.
bore these out and put some small blocks of wood on the sides to level the shelf up and screw them on. cover the shelf with accoustic carpet. place in the boot and your done.
I've got some wood lying around, will anyone make the parcel shelf for me. I'm not very good wood work
if theres money invovled im sure someone could be persuaded, i actually scrapped my old mdf shelf as no one wanted and look now people are crying out for them,
I have one in my seller but you would probably be better off making your own!Its easy to do, just as canavan discribed!You only need a jigsaw and a drill!
CB :thumbsup:
Auto Acoustics Job done, i had one of these it was superb :)
Half in aggreement. Mine still needed alteration after getting it and it was supposed to be a custom fit <_<
How long does it take to make one, I think I'm only in Manchester this month
did you order the correct one, there are two versions
i can knock one up in a day mate. im doin another job for someone else off here as well. ill let u know when i start it. should be able to do it at the same time
Yes i double and tripled checked before ordering and yet......
cheers, just dug out the wood, Its was lost in the celler, its 1100x400x20
Which bit of Manchester are you based?
mine fit perfect :unsure:
Mine was a perfect fit ..... I posted about it somewhere :thumbsup: !
Hi Chris, I need a 2nd shelf making up, the 2nd car is the exact same model as mine. But could you supply the wood for the 2nd one?
cheers
