Urgent Need Help
vmail
Its a problem with a non Toyota, its VW Bora Diesel, maybe some diesel car owners can help me
when I swich the ignition on it sounds like there a three buzzing noise, (like relays clicking on and off quickly)
I also get these four messages randomly
1) STOP
2) Brakes faulty
3) Imobilz Active
4) Service
the speedo and rev counter neadle is hovering and the fuel neadle keeps going up and down
I cant check the voltage as I dont have a multimeter with me, left it in Florida
Its a bit awarkward to roll the car off the drive to see if I can jump start it with my car
Ive got a 6A Battery charger, If I try to start the car will I break the charger
Or is it because of the cold weather
how long has it been stood?
sounds like the batterys dead and the clicking noise is the starter solenoid
the message could be because the brakes could be frozen
the clicking/buzzing may be the starter switch as it does this on alot of new cars
do not try use a 6A charger to start the car,
try charging the Battery while off the car then try see if that makes a difference
been left for two months
ok, Ill leave it on charge for a bit
2 months? and u want to try start it in the cold? there could be countless problems it being sat for this long,
oh and av. life expectancy of a Battery is 3 yrs
:yes:
its dead then without question
also let it run for 10 mins to get the oil flowing
ill say this but with it being a modern car it might get away with it, but you might need to pump the primer if the fuel has gone back to the tank ;)
yup it was the Battery
The alarm went off as soon as I unlocked the car, but I could not disarm it. I could disarm it as soon as I attached the charger.
the car was ment to be started 30mins a week by someone else who forgot.
cars dont like being left my yaris argues with me if i leave it a week,
left the MR2 for a fortnight and refused to start! then lit the EML and wouldnt rev without cutting out!
came back to it an hour later to sort it out and click click vroom it cracked up :huh:
just the cold weather me thinks
my yaris was fine after three weeks, Battery level was a bit low, but it still started up
cheers guys, after 4.5 hours of charge it started up. just left the engine running for an hour
