Tte Rear Spoiler Fitting - Celica
MorecambeStoney
I've been searching for some advice on how to fit my tte rear spoiler, for my Celica. got it of eBay with no fitting kit. I know I can "glue" the middle section to the back of the hatch but there's a couple of screw holes at either end of the spoiler, anyone any idea what these are for and what fitment goes in them. When I dry fit the spoiler the holes seem to fit in the gap between the hatch and the rear wing.
If anyone can help that would be great... cheers :help:
  • 4 weeks later...
If i remember correctly with fitting celica spoilers, the tailgate is drilled and screwed/bolted from the inside, for the centre section a hole is drilled in the tailgate. A plastic 'clip' is pushed into the hole and a threaded metal piece screwed into the spoiler. When you fit the spoiler you put a little adhesive were the spoiler touches the tailgate and put into place. The threaded part on the spoiler pushes into the plastic clip and the ends of the spoiler are bolted from underneath. Alot of the celicas let water in through this middle section and affects the boot lock/boot light switch so make sure it is sealed properly
Hope this helps out if a little late :)
Mart
