Power Take Off 2005 T4
stasu5884
Hi
Does anybody know if theer is a way to wire a 12v power take off in the boot of a T4 Avensis D4D.
I need to mount some radio kit, and don't really want to run a cable from the Battery unless it is really necessary.
Thanks in advance
Mark.
Could you run an extension from the rear 12v lighter, under the rear seat into the boot area-not the most professional but maybe a cheap option!
what you wiring in, amps Etc??
I want to mount an Ham Radio Transceiver in the boot, it pulls a max of 15amp at full belt, but normally will only be pulling about 5amp.
I have been running it off the rear cigarette socket, but it is a bit untidy.
