Help
elgonko
having a nightmare trying to get a power cable for my amp through the bulkhead.
have searched the other posts and tried using the grommit the other members have suggested but there are two pipes, for the air con i believe.the air con system also sits behind this grommit and i cant see any way through it.
is there another easier grommit i could use?
any1 else tried this on a corolla with air con?
cheers
ross
think i might hav found one on the drivers side.
gonna hav to drill a hole in the grommit tho.
ill let you know if it works
