Gen 5 Import Rear Lights Question
mikeb
On the UK spec gen 5 the stop and tail is combined into one segement of the light cluster using a dual filament bulb. The other red tinted segment is used purely for the fog light.
Can anyone with a JDM gen 5 confirm if it uses the twin filament bulb setup for stop and tail?
I have a feeling that JDM cars don't have rear fog lamps, so they could use one segment for the stop light and the other for tail lamp (i.e no twin filament bulbs).
I am planning a rear light mod, and this info will influence my approach.
Thanks.
JDM's don't have rear fogs.
That's what I thought, but do they use twin filament bulbs to combine brake and tail, or are they totally separate? :unsure:
*EDIT*
Ok, it seems that the JDM does use twin filament lamps in both of the red segments to give twin tail and twin brake lights - exactly what I'm trying to convert mine to (whilst retaining the fog light as well). :)
mines a JDM and has twin tail lights but only single brake lights as the others are used for fog lights
Yours has been converted to do so then? The standard set up is twin tail and twin brake
Mine looks like this if this is any help to you? This is just lights on with no brakes or fogs etc..
i dont think i've seen a set of rear lights like those, any more pics of your car mate?
They aint very clear as I took them with a Phone.. but here you go.
That's a very nice example of a gen 5. If I saw one like that for sale I'd probably buy it! The TOM'S Logos would have to go though :lol:
You can buy it off me if you like.. he he
Just found out the donkey has given up the ghost so need to find a new one to drop in.. gutted ;)
My Gen6 Import has two stop and tail lights instead of fog lights so I have the hang down fog light, the bulbs come out easily can you try a twin bulb in the space you are referring to for a quick test?
