Dials/ G6r-sr
nicksSR
Ha any one any tips for the removal of the Speedo/rev counter pod on a 1998 corolla sr? also after a g6/g6r dash with the red dials! where can i get one? many thanks
  • 3 months later...
yes mate i've recently removed mine to change the colour.1/ its best if you diconect the speedo cable first you can find this in the enginebay it comes from the bulkhead to the gearbox you will see that it screws in half before the gearbox. 2/ then undo the x2 retaining screws from the top of black plastic surround around the clocks, you will now be able to remove this. 3/ you will see x2 screws at the bottom of the clocks and x1 at the top remove these. 4/ you will now be able to ease the clocks forward at an angle to enable you to unclip the x2 wiring blocks and the speedo cable. (steering wheels is best in the lowest position for this) its an easy job mate, just take your time and use your common sense:thumbsup: oh! if you find out where theres some G6R clocks for sale let me know cos i'm after some aswell, cheers ,gadge
