Loose Drivers Window.
bert.tsport
hi,
am looking for advice on a small problem on my corolla t sport... if i drive with the drivers side window open a bit , the glass slips forward a bit and starts to rattle on bumpy roads. i can pull it back and it stays tight for a while but its a pain really.
anyone had this problem, or know how to fix... or should i get it done on warranty? not sure mr t will do it though, as he may say its due to having 35mm lowering springs??? stiffer ride you see... :help::help:
:thumbsup: bert
hi,
anyone had this problem, or know how to fix... or should i get it done on warranty? not sure mr t will do it though, as he may say its due to having 35mm lowering springs??? stiffer ride you see...  :help:  :help:
:thumbsup: bert
i can't see Mr T having a problem with the warranty, the springs wouldn't have loosend the window lifter, cos that's what it sounds like, prob just loosend a bolt or screw. but i would still get it done under the warranty even though its a simple thing.
hi,
:thumbsup: bert
cheers, its going in on thurs to have window fixed under warranty.. :thumbsup::thumbsup:
