Camry Aerial Pole
I've just found this forum. I've just purchased a 97 Camry 2.2 and need to replace the aerial pole. Is this a straightforward procedure? The motor seem to be working but the pole is missing so I've ordered a new pole.
Cheers
Hello and welcome :)
You might just be better off posting this in the Camry ( Toyota Executive)forums :thumbsup: where there are more people who might be able to help you :group-cuddles:
hi
the procedure is very simple:
undo nut around the aerial pole
switch on ignition and radio so that motor unwinds - this should allow you to remove the old aerial
with the new aerial (closed) insert the nylon cord so that the cogs are facing towards the front of the car and push down as far as it will go and hold
ask a second person to switch off the ignition at this point - the aerial should go down
replace nut
hope this helps
regards
miq
sorry just read "your pole is missing" so ignore the bit about removing it
regards
miq
