Steering
Nick SR
On my 2001 SR, the steering is feeling very very heavy when it gets about half way through the steering lock both ways, fluid was fine when last checked, however it does seem a bit noisey, tyre pressures are also fine
Anyone got any suggestions as to what would be causing this, so i have an idea before it goes into the garage tommorow.
Nick
if the belt had snapped wouldn't it be heavy all the time.
if not the case where do i check the belt?
and is there any other possibilities?
Nick
check tyre pressures mate
He has already doen that
"tyre pressures are also fine"
