im gonna be doing some work on a turbo mr2,its had a blink code read and its saying map sensor fault.......
the car is lacking power
oil coming out the turbo outlet,is this as i suspect.........:o
when the dump valve was fitted the dump valve was almost perm on "dump" only slight accelerator pedal release was required b4 "hiss"
anything from the norm i should be looking for..
whats the best option from here if the turbo is goosed.....
i even think it may be an actuator fault,how best to test it?
thanks
mat
