Pas
burfitt101
Hi there, when the steering is applied it makes abit of a noise, when not used its quiet. i know it may make a sound when used but this sounds quiet loud.
the levels appear to be fine and so there is no obvious leak around. but i dont know if the fluid has been changed. could this may be the fault here. just a bit of advice if possible thanks...
james
what kind of noise , if its a squeel on full lock its normal , if its squeeling alot the belt maybe needs changing or at least tightened up.
its not a squeal as such it sounds more like the transfer of fluid,however it just sounds louder then maybe it should be. thanks il check out your suggestions.
