Lowering Springs
burfitt101
other then the lowering springs theselves is there any other components that i may require?
which are the best to get for a st185? and where to look(eBay i expect)?
also wheel spacers, are they worth having or do they not make much difference? are they quite noticeable?
thanks very much
james
which are the best to get for a st185? and where to look(ebay i expect)?
thanks very much
james
Just my opinion. But i`ve got spax springs 35mm drop which i find are just about bearable on our cruddy roads. and you would probably need to get uprated shocks if yours are getting tired, otherwise the car will feel a bit over sprung. Also you would need to have the camber adjusted on the front. Which would mean buying camber bolts as the 185 isn`t blessed with adjustable front camber as standard. I got some whiteline ones from FENSPORT. If you`ve got lots of money you might want to consider something like TEIN adjustables. I got my SPAX ones from spax themselves. Wouldn`t bother with wheel spacers personaly. Once the cars been lowered the arches look suitably filled. :thumbsup:
where do these camber bolts go then daktari ? i think the 185 set up is very similar to the 202 is it not ?
found this looks fairly easy to do.
http://www.ingallseng.com/parts/81290.htm
Yep. :thumbsup: They go in the bottom one of the two bolts that fix the strut to the hub. Thus giving you up to 1.5 degrees of camber adjustment. They have an ecentric shoulder on the bolt that moves the hub when you turn the bolt. Full instructions provided. :thumbsup:
Although they were written by an australian who couldn`t give a XXXX about clear and concise. :lol:
I was under the impression that the 202 camber was adjusted by the through bolt between the lower arm and the subframe. :unsure: Same principle tho.
Just had a look at the link again. 4 hours per side????? Thats half hour to do the job and 3 1/2 for the barbie then. :lol:
look closer mate it states point 4 of an hour , maybe tis you on the xxxx. :lol:
i found this site and called the guy , who chatted to me for 32 minutes , knows his onions too , helped me immensely and even sending me the bolts , didnt know that kind of person still exists in todays society .
http://homepage.ntlworld.com/anthoney.bones/
My bad. :D Not 4X ...... JD. :P
Top site. Bags of info. :thumbsup::thumbsup:
i'm running a 30mm drop on eibachs. very good.
wheels spacers look better - try a set of deep dish instead imho wider wheels grip better.
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
