Tyre Wear
popwud
Tyre wear...........front left 222 front right 333
rear left 543 rear right 666
inner/middle/outer
These tyres have been put on new in pairs.....front and rear........
what do you reckon is causing uneven wear......or is this normalish.
Do you have any idea why the rear left has an odd wear pattern.
Best answer can have a ride on me bike. :D
                                    inner/middle/outer
NSR in a toe out position... 543 reads like lateral wear, if the depths were 552 then camber would be the suspect.
HI THIS MIGHT HELP IT COULD BE A WORN SHOCK ABSORBER  HOPE YOU FIND THE PROBLEM SOON
Due respect (how?) the absorber reacts in a negative format to control the coil release, 80% of the time... yes gas has a positive resistance but neither would cause this type of wear. Coil 'sag' or a broken coil would displace the camber but the effects in the drive would be very detectable to the driver.
Be gentle in reply, this is only my opinion..... :thumbsup:
a bent axel or worn bushes? im not sure... get a four wheel alignment check :thumbsup:
Hi Popwud
Just I idea. Do you go round many roundabouts? As it would wear out the left side quicker. Especially the front left.
Pb
:wacko:
Is that a serious question pb5.....never heard of that before......but what would make the other tyres wear at different rates evenly. :blink:
Only an idea after all. :D But it would mainly effect the front left on the outside edge (probably not the whole tyre width).
pb
:wacko:
