Milleage Displays In Km's Not Miles?
cookci
as title but its now adding onto the total of 107000 KMS in miles now so soon the milleage will be incorrect...
is anyone able to tell me how to change it?
Also there is a weird knocking noise coming from the front (both sides). I cant see any loose bolts or maybe im trying to tighten up the wrong ones. The noise is very hollow and is very frequent at slow speeds on a bumpy road.
please help :help::help:
christian
Are you sure? what is the top speed on your speedo? On non turbo supras they normally change the speedo face rather than fit an electronic convertor.
There was a guide somewhere on how to change from km to mile but it requires soldering on the back of the odometer. Not really worth it...
The suspension could be nothing...but at the same time it could be something so get it check out dude just to be sure :thumbsup:
the dials are the original dials with a MPH sticker covering up the KM!
Can i change the milleage from 107000KM to say 68KM's? Is that doable?
then it would be worth changing the KM to display M instead
Check the mk4 supra sites dude, im sure i saw instructions on how to do this :thumbsup:
AS the knocking seems to be comming from both sides I'd say check you raoll bad drop links and bushes!!!
the drop linsk tend to go, and often get mis diagnosed as lower ball joint....
the knocking noise could be the brake pads. some people when changing the pads dont change or replace the shims.
try touching ur brakes at low speed and see if the knocking stops????
i had the same problem on my car....had to strip the brakes down and replace all the shims. dont forget to use copper slip when fitting.
hopefully i've been of help. keep us informed.
baz
