Carina E Rear Washer Bottle
MonkeyMD
I have a 96 Carina E. Does the rear window washer have a seperate reservoir for fluid or is it the same one as the front? I am asking because it worked for a while and now it doesn't. I just wanted to make sure it wasn't for lack of washer fluid.
Any help appreciated.
There is only one reservoir for washing fluid and there is only one motor for the pump too. There is a relay inbuilt in the pump that decide where the water will come.
LM
Same bottle at front. 2 seperate feeds. Check connector to rear jet and then trace back to front. Could visbily check from front bottle
Thanks for the replies. How do I trace the connection back? I mean, where do the pipes/tubes run? So it could be that or the relay since the fronts are working fine?
