Stereo Blackout
Blackarisman
Hi all,
A new member here, this is my first thread.
I have a Yaris TSport 02 reg, yesterday the CD popped out for no reason, so I put it back in and the whole system packed in. No power to the unit whatsoever. Could it be an in line fuse? Is it easy to remove the unit to find out? All help will be received with gratitude. :help:
possibly the fuse yes
as if you disconnect the power or it looses it, then the CD is ejected so its not stuck inside! quite conciderate from toyota i suppose
