Been A Busy Weekend.
daktari
Well i`ve been threatening to do it all winter. And now springs just around the corner I thought today would be a good day to start. Fatso needs to slim down some more.... :yes: So out with the old.
Rear shelf and two 6x9`s ... two 7 inch Speakers behind the rear passenger trims... Space saver.. Boot carpet... jack & tools....Rear seats & associated bracketry.... All 4 inertia belts, bolts, clips etc... And finally i`ve repositioned the Battery. Thats 7ft of heavy duty cabling less. Amazingly all this lot adds up to 130 lbs give or take a pound. :eek: I was going to remove all the side trim but altogether it only weighs about 10lbs and it looked a bit too spartan. :rolleyes::huh:
Also took the opportunity of fitting the rear strut brace. :D
I`ve not been overly happy with the Battery where it was. The cable runs were too long and causing a delay between turning the key and the starter turning. only half a second or so but not what i wanted. Where it is now is just fine...... I think. B) Still got to sort out a Battery box and get a smaller battery. :)
That enough for this weekend. Off to the pub now. :D :thumbsup:
Looking good now mate - what's the kerb weight down to?
It was 1283 KG When it was weighed back in October. So a bit of mental math and we have a figure around about 1225KG give or take. :D Which is a good bit less than the standard 1380KG.
And the performance thingummygig HERE says
Power at Flywheel (BHP) : 250
Weight without Driver (KG) : 1225
Power to Weight Ratio (BHP Per Ton) : 207.36
0 - 60 (Secs) : 4.84
0 - 100 (Secs) : 13.26
60 - 100 (Secs) : 8.42
Quarter Mile (Secs) : 13.59
Terminal Speed (MPH) : 101.24
Drag Strip Quarter Mile (Secs) : 13.19
Drag Strip Terminal Speed (MPH) : 104.50
Assuming that the old beast can actually manage to poke out that many ponies at the crank without spitting it`s dummy out. :lol:
Standard JDM ST205 is -
Power at Flywheel (BHP) : 255
Weight without Driver (KG) : 1440
Power to Weight Ratio (BHP Per Ton) : 179.93
0 - 60 (Secs) : 5.51
0 - 100 (Secs) : 15.10
60 - 100 (Secs) : 9.59
Quarter Mile (Secs) : 14.25
Terminal Speed (MPH) : 97.15
Drag Strip Quarter Mile (Secs) : 13.85
Drag Strip Terminal Speed (MPH) : 100.16
And a 2005 Impreza WRX is
Power at Flywheel (BHP) : 247
Weight without Driver (KG) : 1360
Power to Weight Ratio (BHP Per Ton) : 184.53
0 - 60 (Secs) : 5.38
0 - 100 (Secs) : 14.82
60 - 100 (Secs) : 9.44
Quarter Mile (Secs) : 14.13
Terminal Speed (MPH) : 97.65
Drag Strip Quarter Mile (Secs) : 13.73
Drag Strip Terminal Speed (MPH) : 100.70
Unfortunately it`s all theory... Need a track. :yes::thumbsup:
Dude that's not obsessive in any way,
What do you use to listen to music on then if you have whipped out the 6 x 9"s ?
Sorry my mates Scooby is doing 0-60 in 4.8 secs. He has a UK300 with the pro drive upgrade, that said I am !Removed! impressed at your figures and feel rather inadequate having only a 3s-fe
boo hoo
Dude the pics have finally loaded on my dial up connection (lol I know) do you only use this car for the track? refer to my previous comment about non obsessive behaviour :yes:
boo hoo
Its not obsessive........... Is it????? Oooer :wacko: You want to see Monster mats IS 200 drift car.... Thats obsessive. :yes:
I still got the front Speakers in. Only 100w jobbies but the engine makes much better music. :yes:
Unfortunately the figures are only subjective, although i don`t think they`ll be too wide of the mark. And there`s still more to do. Looking at metal HG and Water/Methanol injection next. I was thinking of shoving a ST205 lump in but the price would be a little prohibitive for the gains. Apparently forged internals, bigger injectors and different fueling will all produce good results.
The problem with where i live is it`s all windy little B roads so i`m not interested in outright speed. Anything over a 70-80 MPH is wasted anyway unless your on a track. I`m after acceleration. Already reduced wheel size back to 16" from 17`s. This has reduced the unsprung weight a little and reduced the gearing slightly as well. And if 2k were to become available (Here`s hoping :rolleyes: ) then i think a Quaife box/dif might be in order. Maybe....
Oh and the cars SORN`d at the moment while i wait for spring then it`ll be in regular use with hopefully a few track days thrown in for good measure. :thumbsup:
B)--><div class='quotetop'>QUOTE(Tom.B @ Jan 17 2006, 10:42 PM) </div><div class='quotemain'><!--quotec-->
:thumbsup: think its time oyu sold it m8...to me :D :D :D :D :D :D .....love it sooomuch!!!!
Keep it up matey :thumbsup:
Cheers Tom.. :thumbsup: `bout time you got one sorted out. :yes:
