Tns200 Sat-nav System
bhinderharminder
thinking of gettin a tns200 system of eBay, i read on the forums that the wiring is already in the car nr the boot, i've been searching allday and could'nt find anything, dose anyone know where abouts it is or will i have to install a new wiring system?
car is a 2002 t-spirit corolla 5dr.
Cheers B)
Pretty sure the wiring won't be in the boot - you have to install the DVD-ROM unit in the boot and feed wiring through the car to the head-unit. :thumbsup:
hi the wiring is not already there. you need to get the wiring and gps aerial and they will plug into your head unit. if buying off eBay make sure you get all the wiring as it is very expensive. try ngetting tns 300 its a lot better than the 200 :thumbsup:
