Previa model 2001 2ltr petrol & Rav model 2002 2ltr petrol both have same symptons. After long runs MIL lamp comes on, same fault codes on both vehicles suggests all four lambda sensors. come on that can not be right, but fitted all four to the Previa (at great cost) still the same. both vehicles have about 48K on the clocks, both run & perform fine. MIL stays off untill 2 or 3 hundred mile run.
any thoughts would be massively appreciated.
regards Steve
The fault codes only display the apparent fault that the engine management is seeing. But this can be caused by a number of things in reality.
Personally i'd go for either Cat failure, or the MAF sensor can sometimes give faults like this. Generally, a fault code won't point to all four lambda sensors, they tend to at least narrow it down to a bank. But, really this should be looked at by a Toyota garage - and i mean one that knows what they are doing!
theres an ecu software update available and replacement cat is common especially to previa
Mainly sensor faults on rav, need the fauult codes really
DI–18
DIAGNOSTICS – ENGINE
DI12C–11
DIAGNOSTIC TROUBLE CODE CHART
SAE CONTROLLED
HINT:
Parameters listed in the chart may not be exactly the same as your reading due to the type of instrument
or other factors.
If a malfunction code is displayed during the DTC check in check mode, check the circuit for that code listed
in the table below. For details of each code, turn to the page referred to under the ’’See page ’’ for the respec-
tive ’’DTC No.’’ in the DTC chart.
DTC No.
(See Page)
Detection Item Trouble Area
CHK
ENG*1 Memory
P0100/31
(DI–26)
Mass Air Flow Circuit Malfunction
Open or short in air flow meter circuit
Air flow meter
Engine ECU
P0101/31*2
(DI–32)
Range/Performance
Problem
Air flow meter
P0110/24
(DI–33)
Intake Air Temp. Circuit
Malfunction
Open or short in intake air temp. sensor circuit
Intake air temp. sensor (built into air flow meter)
Engine ECU
P0115/22
(DI–39)
Engine Coolant Temp. Circuit
Malfunction
Open or short in water temp. sensor circuit
Water temp. sensor
Engine ECU
P0120/41
(DI–46)
Throttle/Pedal Position Sensor/
Switch ”A” Circuit Malfunction
Open or short in throttle position sensor circuit
Throttle position sensor
Engine ECU
P0121/41*2
(DI–52)
Switch ”A” Circuit Range/Performance
Problem
P0125/91*2
(DI–53)
Insufficient Coolant Temp. for
Closed Loop Fuel Control
Air induction system
Fuel pressure
Injector injection
Gas leakage on exhaust system
Open or short in heated oxygen sensor (bank 1 sensor 1)
circuit
Oxygen sensor (bank 1 sensor 1)
P0130/21
(DI–53)
Oxygen Sensor Circuit
Malfunction (Bank 1 Sensor 1)
EGR system
Fuel pressure
Injector injection
Open or short in heated oxygen sensor circuit
Heated oxygen sensor
P0133/21*2
(DI–60)
Slow Response
(Bank 1 Sensor 1)
EGR system
Fuel pressure
Injector injection
Engine ECU
P0135/21
(DI–63)
Oxygen Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 1)
Open or short in heater circuit of oxygen sensor
Oxygen sensor heater
Engine ECU
P0136/27*2
(DI–65)
Oxygen Sensor Circuit Malfunction
(Bank 1 Sensor 2)
Oxygen sensor
*2
DI–19
P0141/21*2
(DI–63)
Oxygen Sensor Heater Circuit
Malfunction (Bank 1 Sensor 2)
Same as DTC No. P0135
P0171/25
(DI–67)
Fuel Trim System too Lean
(Air–Fuel Ratio Lean Malfunction,
Bank 1)
Air intake (hose loose)
Fuel line pressure
Injector blockage
Oxygen sensor malfunction
Air flow meter
Water temp. sensor
*2
P0172/26
(DI–67)
System too Rich (Fuel Trim)
Injector leak, blockage
Mass air flow meter
Engine coolant temp. sensor
Ignition system
Fuel pressure
circuit
Heated oxygen sensor (bank 1 sensor 1)
P0300/93*2
(DI–73)
Random/Multiple Cylinder
Misfire Detected
Ignition system
Injector
Fuel pressure
. Compression pressure . .
Valve clearance
Valve timing
Air flow meter
Water temp. sensor
Open or short in engine wire
Connector connection
Engine ECU
P0301/93*2
P0302/93*2
P0303/93*2
P0304/93*2
(DI–73)
Misfire Detected
– Cylinder 1
– Cylinder 2
– Cylinder 3
– Cylinder 4
P0325/52
(DI–79)
Knock Sensor 1 Circuit
Malfunction
Open or short in knock sensor 1 circuit
Knock sensor 1 (looseness)
Engine ECU
P0335/12,13
(DI–82)
Crankshaft Position Sensor
Open or short in crankshaft position sensor circuit
Crankshaft position sensor
Signal plate
Engine ECU
P0340/12
(DI–84)
Camshaft Position Sensor
Circuit Malfunction
Open or short in camshaft position sensor circuit
Camshaft position sensor
Engine ECU
P0420/94
(DI–86)
Catalyst System Efficiency Below
Threshold (Bank 1)
Three–way catalytic converter
P0500/42
(DI–89)
Vehicle Speed Sensor
Malfunction
Combination meter
Open or short in No.1 vehicle speed sensor circuit
Engine ECU
P0505/33
(DI–92)
Idle Control System
Malfunction
ISC valve is stuck or closed
Open or short in ISC valve circuit
Open or short A/C switch circuit
Engine ECU
P1300/14
(DI–97)
Igniter Circuit Malfunction
(No.1)
Open or short in IGF and IGT1 circuit from ignition coil with
igniter to Engine ECU
No.1 ignition coil with igniter
Engine ECU
DI–20
P1305/15
(DI–97)
(No.2)
Open or short in IGF or IGT2 circuit from No.2 ignition coil with
igniter to engine ECU
No.2 ignition coil with igniter
Engine ECU
P1310/14
(DI–97)
(No.3)
Open or short in IGF and IGT3 circuit from ignition coil with
No.3 ignition coil with igniter
Engine ECU
P1315/15
(DI–97)
(No.4)
Open or short in IGF or IGT4 circuit from No.4 ignition coil with
No.4 ignition coil with igniter
Engine ECU
P1335/13
(DI–104)
VVT Sensor Circuit Malfunction
Open or short in VVT sensor circuit
VVT sensor
Engine ECU
P1346/18
(DI–105)
VVT Sensor Circuit
Range/Performance Problem
Mechanical system (Jumping teeth of timing belt, belt
stretched)
Engine ECU
P1349/59*2
(DI–107)
VVT System Malfunction
Valve timing
OCV
VVT controller assembly
Engine ECU
P1520/95*2
(DI–114)
Stop Light Switch Signal Malfunction
Short in stop light switch signal circuit
Stop light switch
ECM
P1600/96*2
(DI–117)
Engine ECU BATT Malfunction
Open in back up power source circuit
Engine ECU
P1645/82
(DI–119)
Body ECU Malfunction
Body ECU
A/C ECU
Communication bus
P1656/39
(DI–120)
OCV Circuit Malfunction
Open or short in OCV circuit (bank 1)
OCV
Engine ECU
P1690/39*3
(DI–123)
OCV Circuit Malfunction (for
VVL)
OCV for VVL
ECM
P1692/39*3
(DI–127)
OCV Open Malfunction (for VVL)
OCV for VVL
ECM
P1693/39*3
(DI–127)
OCV Close Malfunction (for VVL)
OCV for VVL
ECM
*1: – Check engine warning light does not light up.
Check engine warning light lights up.
*2: European spec. only
*3: 2ZZ–GE only
And what are the Lotto numbers for tomorrow please shutty :)
hmmm
Cant help on that score i only know tonights for the euro one
sorry
