Disable Seatbelt Warning Beeper Sound Procedure
src
Another trick to list :-
1) Turn the Power ON
2) Set trip meter to "ODO"
3) (you may need to Power OFF at this point)
4) Turn the Power ON
5) Hold down the ODO/Trip button for 10 seconds
6) While keeping the ODO/Trip button down, put the driver seatbelt on.
7) You will see b_on / b_off choice in the ODO meter, make your choice with the ODO/Trip button
The the seatbelt warning lights will continue to flash until driver and passenger put there seatbelt on.
And please wear your seltbelt when driving on the road.
  • 1 year later...
This does not seem to work on my March 07 XTR D4D 140. "turning off the power" = turning the key back to the accessory power position, completely off, or out of the keyhole?? Not that it matters - I tried every combination and it still refuses to play ball. I am sure the dealer can do it next time it is in for a service, but it is a little irritating in the meantime.
J
Tried it myself this evening and couldn't get it to work. :crybaby:
I put my laptop bag on the seat when I'm driving and it detects as a person an beeps so would love for this to work.
Can you confirm if you have done it yourself or did someone tell you about it?
I've got a 2006 XT5 which was newly delivered in June last year, I take it from above yours is later than mine so don't think its a version issue at the moment.
Anyone else got this to work?
better to place your laptop bag in the footwell area... with the first emergency brake and you can buy a new laptop...
