Headunit Access
chenks
ok guys, just received my dension ipod kit
all it requires me to do is plug a cable into the cd changed port at the back.
so what is the easiest way of getting to this without destroying my dashboard.
i plan to fit the rest of the kit in the glovebox area, as it's nice and close to the headunit anyway.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
  • chenks
    19
  • Johndcfc
    5
  • p11p
    4
  • man-bing
do a search for man-bing, he has put up pictures showing how to remove the headunit!!
whats the model number for you headunit? I thought that denison hasnt bought out a kit for toyota yet??
could you let me know if the kit fits?
i believe it does involve removing certain sections of the console though to get to it ?
just follow the pics, start by removing ash tray and then gear cover, undo the two screws at each side, pull the centre heater control off if you have one, if not it should remove straight away.
their is then 4 screws holding the radio in position loosing these and your radio will unplug then you will be able to fit it
sounds easy enough... i'm sure i'll end up with a cardboard dashboard at the end of it !
it does fit... it's specifically designed for toyota headunits as listed on that site above
jus want to make sure because to connect2 kit i got was suppose to fit, but it didnt!!! whats the sound quality like. I notice that the model of your headunit is W58818. Mine is W58814. wonder if it has the same ports. Does the rear of our headunit look like this?
sorry about size of picture :(
Really useful picture, Thanks! (I have the 58814 as well).
Which of those sockets has something attached to it in yours?
David.
haven't got it out yet.. but my cd changer port is 2 rows of 6
others have 1 row of 7 and 1 row of 5
any chance you can take some pics of the rear of your headunit and with the kit connected before you but it all back together?
David.
i know that three of the sockets are used!! cant remember which ones those, i'll have a look next time my headunit is out!
My tip is :
When you pull the centre console out (one with the climate / temperature control buttons) put a cloth/duster etc on top of it, otherwise you might scratch the plastic when the stereo comes out.
Opps bit late to add reply, but oh well...
If your still stuck, click on my signature and have a look
:thumbsup:
ok have hit first snag
have removed the centre console... but there aren't any screws visible holding in the headunit
i have what this image shows
you might have to take out the heater vents as well, if you do they are just clipped in so they should be easy to remove
ah... 4 bolts (rathers than screws)
i have got the front 2 out.. but the back 2, my ratchet is about 1inch too short to reach them !! arghh!!
well they are called screws in the manual :P
why's everybody making this look hard work :lol:
Click here and view my pics, should help alot
BTW, i can get the H/U out in about 5mins!!!! very easy :thumbsup:
i know how to get it out !
the problem i have is my ratchett set won't reach the 2 back bolts!
Haven't you got an extention bolt as well within your set? should have
