Srs Airbag
steve3621
usually bad connections, check the connections under the seats. disconnect the plugs and twist the metal pins slightly to make a better fit. make sure not to touch/short out the pins as this could set the bag off!!
Maybe best to disconnect the Battery and leave for 10-15 mins just to make sure.
Mart
