Could some one please share with me how to remove the front foga on my '90 so I can check the bulbs.
Cheers
Paul
drill out the bolts and then break the mounts off the top that hold it to the bumper ..
:o :o :o :o
Is that reversable :eek:
Is it simpler to take out the bulbs
Paul
unscrew the surround of the fogs.. then take out the unit and then pop off the plastic cover behind it to get to the bulb..
Or you could try doing it the correct way and unscrew the 2 bolts at the top of the lamp :huh:
Soak them in wd40 before you do, they tend to get a little rotten but can be worked out with patience
Yeah, when I put my kit on, couldnt remove these bad boys !
Ripped em off in the end !! Werent going back on, so I didnt care, but there are screws there...and mine were well rotten and rounded...defo a WD40 spray a day before !
mine soaked for a week .. and then were drilled out .. how much would it have cost Mr T to use stainless?
Found those screws, well rusty blobs, already rounded from previous owner.....
Looks like the drill will be out next.....
Unless I change the front end.
Paul
Had the same problem with mine in the summer totally rounded and rusty as hell. I left them as i didnt have time due to a new job. Let me know how you get on and the solution you used?
Cheers mate
