Toyota Corrola G6
ChrisG6
Hi Guys,
I've been looking at a 1.3 R Reg Toyota Corrola G6.
Are there any known problems that I should watch out for?
Also, the ABS light is on when the car is running and the car wobbles at about 70mph. I'm not too concerned about the ABS as the brakes still work fine (but without ABS) and i'm thinking wheel balancing about the wobbling problem.
Am I on the right lines?
Thanks for any help.
could be but i would get the ABS fixed as it will fail the MOT if the light is on.
check for play in the front hubs first if ok then it will most likely be balancing.
the ABS problem could be just a dirty sensor or connection but it could also bea busted sensor (about £130 from Mr T)
