New To Forum With 51 Plate Celica
Dave & Marianne
Hi All
As you can see i am new to the forum so please bear with me .
I have just taken my Celica for a 50k toyota service out of warranty and they have informed me on a visual report that the Altinator belt is making a noise and replace it would cost £203
My question is just because it is making a noise does it need to be replaced it only whistles slighty
Can you help
Dav
Hi All
Can you help
Dav
Hi. Welcome to TOC :thumbsup: The alternator belt problem is quite a common one apparently. I think you`ll find a few threads about it here. I do believe the solution is to use a silicon spray on it. Not sure where i saw it but it`s here somewhere. :thumbsup:
** edit ** Found it Squeeling belt :thumbsup:
Hi there - welcome to TOC! :thumbsup:
I'm afraid the alternator belt tensioner is prone to failing - mine has already been replaced twice on a 54 plate T-Sport and looking at having it replaced again tomorrow at its 20k service!
You could try the squeeling belt solution suggested in the thread Daktari found - otherwise I'm afraid it'll have to be a replacement. :(
Hi All
Can you help
Dav
Thank you for your Welcome
Looks like I will have to go and see Mr T
If you are going to spend £203 with Mr T you might want to consider a Gold membership first ;)
If they are just quoting to replace the belt, then £203 is an obscene price. :o Or does that price include the tensioner pully.
Don't put anything on the belt itself. If the squealing is the belt slipping then I guess the tensioner must have failed (or maybe just the belt has perished). If it's more like a whining or whistling sound, then it's likely to be the idler/tensioner pulley bearing. These need lubricating fairly regularly. A good dealership/technician will lubricate it, a dodgy one will sell you a new tensioner pulley. :thumbsup:
It is a whistling sound And they do want to sell me a new one.
Thank s for your help will go back and have words with them and ask them to lubricate it :)
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
