How To Reset The Ecu?
frodo
Coming from an ST182 I don't have a wiring diagram, so don't know which fuse to pull to reset the ECU on my ST205. It was an EFI fuse on the ST182. Is it the same on the ST205, and if so where is it?
engine bay mate , its a blue 15 amp , says ecu on the fuse box cover , top row second on the left IIRC. ??????
found the efi fuse. right hand side of the engine bay. long fuse box. looking along the length of the fuse box, left hand side blue 15amp.
is that the one, or is their a specific ecu fuse?
Turn over the Fuse Box lid, there is a diagram on the underside :thumbsup:
You need to remove any fuses that correspond to EFI & ECU.
Or as I personally do, just disconnect the Battery and pump the brake pedal to discharge any power rather than play with the fuses :)
Or as I personally do, just disconnect the battery and pump the brake pedal to discharge any power rather than play with the fuses :)
NOOOOO!!
Remember what happened to Ed when he did this after I advised him not to? :lol:
NOOOOO!!
:lol:
Yes but Ed bought a car without the master key which disables the immobiliser :rolleyes::lol:
Yes as a side point, if you have an immobiliser then make sure you can disarm it :thumbsup:
sorry i imagined you had a st205 , the fuse i gave maybe the same but i dunno , ask someone with a 182
He HAS got a 205 .. he's come FROM a 182 ;)
fuse 4 , in the long box under bonnet then. its marked on the lid , take a look.
there is a fuse marked ECU in there mate
