Rear Light Unit Flooding
jmcb55
My Carina E 5 door hatch back rear light unit containing the break light, side light etc.. on the drivers side keeps filling up with water. Has anyone else come accross this problem and found a fix.
I removed the unit and siliconed around it - this gave a temporary fix (also coinciding with summer) but the leak is back.
Any ideas?
Might be worth getting some replacement rear lights off eBay if you can find some, might be the outer casing is cracked somewhere letting water seap in.
  • 11 months later...
- Has anyone else come accross this problem
Yes
- and found a fix.
No. I can't even get the unit to come off - it's just making snapping car noises.
Anyone know which way to yank it?
To answer my own question - after the screws have come out backwards, the clips need to come out sideways. It occurs to me that just replacing a bulb could introduce leaks because the seal will have gone brittle over time and the removal procedure involves a certain amount of force against that seal.
To find the leaks, I've filled it with water and turned it slowly around. It has two points leaking - top front and side front. It's currently perched on a radiator. I'm going to scrape out and plug just the leaks with sealant and then grease the clips before putting it back on so I don't have to give it too much pressure (which would probably break the seal again).
Hope this helps.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
