Stereo Gone All Wrong
right i had all my Speakers and subwoofers working fine and today i got a new map a better one a four channel amp
wired that up just like normal the same with the other 2 channel amp and then nothing works through the amp.
so i thought maybe the amp is buggered my new one but i pu tthe old amp in and nothing.
both amps shows they got power running to it and the wire from the amp which goes to the head unit is fine
but i think it might be my headunit rca leads output because i get no sound coming through my rca leads which lead through the back to the amp and have no sound and now my stereo works normal but cant use the rca leads i think not sure
please help me i am so stressed about this.
cheers acstreet
So your RCA outputs are defo in your headunit .. and you are getting nothing out the Speakers.
Take the RCA connectors off the HU and tap them together, do the Speakers crackle?
Have you hit mute by accident?
How are your Speakers wires up?
i have took my headunit out so can see all the wires so defo the rca leads are in and now mute i havnt hit that and i put the rca leads to a subwoofer and nohting happens
do you think it might be my headunit output dead
Speakers on crappy standard amps but they work its the subwoofers that dont becuase for some reason no amps are givin out to any of my subwoofers i disconeected all the subs and connected one of each n none of them work
seems to be no sound coming through
sounds like a defo RCA output problem
If your normal Speakers are working fine, then its not mute on the HU.
If the amps have power, then the earth and power must be ok.
If our sure the remote lead from the HU is ok, then the only thing left is RCA output from the HU
Dont know what to sugest to try and resolve it though, if you have already tried your old amp back in the system ,it must be the HU !
Okay .. so the Speakers are still on stock loom are working.
So if you disconnect the RCA's for the sub, and rub em together, still nothing? You should get a crackle.
You got anything else you can connect to the speaker end after the amps? Like another speaker?
Speakers are on stock loom still work
the headunit shows that the Speakers are playing which they are and thats it so thats no help and i have not got any other head unit
im totally puzzled and the moment so stressed out !Removed! stereos and electronics do my head in
Defo sounds like the RCA's are doing nothing.
On mine I can set the volume on the RCA's separatly (Alpine, push the volume button and it selects Volume/Fade/Sub/Front/Rear .. )
what so you think its the rca leads or the output ones from my HU
if its the HU will i have to buy a new headunit.
dont no what to do or try at the moment
could it be the remote lead knackered i dont know but it looks all connected fine im guessin its rather that or my head unit buggered or the rcas
Without looking I couldn't tell you ..
Is the power lit up on the amp? Is the volume up on the amp?
Have you tried with new RCA cables (same as on a seporates stereo)?
How about the sub wires? are they connected proper?
everything seems to be normal but il have a look tommorrow in the daylight and see what i may have done wrong
and yes the power is lit up on the amp
i will try all the things you have suggested tommorrow so i will have a fresh mind
cheers bibbs great help once again
andy
No Problem.
If the amp is powered, that'll be the remote wire is okay.
Need to check ..
1. The HU is sending a signal
2. The amp is getting it
3. The amp is sending a signal
4. The Sub is getting it
And when we have a "no" that'll be the issue :)
right i put my output of the back of my headunit to a subwoofer and nothing happens and dont no wether this is anything to do with it but anyway all my dad says is the headunit is buggered.
if i take some piccys would it be easier for you to help
think ive decided its possibly my headunit is buggered its pretty crap anyway to be honest so it maybe that im not sure
will put some piccys up if needed
cheers
acstreet
what do you think of this headunit may aswell start looing as it sounds liek mines knakered well the output is
will sell it to my dad beacuse he hasnt got one in his astra
what you think bibbs does it sound like its dead
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...AMEWA%3AIT&rd=1
I'd do bit more digging with the current one.
The Alpine looks good .. I've got a very similar one. Love Alpine units, total quality.
going to get my dads friend to look at the headunit but i think i will go for that alpine one anyway because its much better than mine with the features and stuff its got and then give the old one to my dad or something..
cheers bibbs fro your quick responses will let you no how it all turns out
andy
Agreed...I have an Alpine 9 series MP3 player, top HU.
Love the Alpines !
I know its a pain, but id try another HU in your car 1st if you can, or yours in another car. if you dont wanna buy a new one that is !
i have now got some alpine Speakers to replace the rubbish ones in the doors and now have alpines up front and alpines in the rear
also have a new alpine headunit which i gotta put in i have to rewire the whole lot as who ever done the old headunit has ruined all the wires behind the headunit so gotta do it all the hard way
will post pics once all done also behind the the seats i have mounted in the shelfs of the storage boxes a 3 way speaker each side and they sound awesome but.
once i get that new headunit in then i will have 3 subwoofers in the boot and alpine Speakers up front and rear and some threee way Speakers behind the seats also wil be able to connect my ipod to my new unit..
cheers
andy
