hi guys got some hks bit give to me foc which was really nice of the guy but im after any info that you can give me
been give a hks electronic valve controler in mint nick
http://www.hksusa.com/products/?id=672
anybody used one of thease.
bin given a hks turbo timer http://www.mr2.com/OWNERS/GRAPHICS/gs_turbo_t.jpg
bin given a sard racing attack meter
http://www.uniqueautosports.com/pricelists...electronics.htm
http://www.uniqueautosports.com/pricelists...attackmeter.jpg
anybody ever used thease could you give me some info on if they are any good
cheers daz
I've got the same timer .. what you need to know?
ok iv got the timer no instructions iv got a block that plug into the timer wiring loom,and that's got a red green and blue wires on it then you got the timer loom which has 1 plug with the same wires in plus a separate black and grey wire where do the wires go and are they a good timer where could i possiblely get so instruction from
hope this helps cheers bibbs
Darren the pictures are blurry babe, want me to take them?
Actually, there are a number of devices made by the Japanese tuners. I am currently using the SARD Attack Meter. This installs on the dash and hooks up to the ECU box. Asides from giving you a wealth of information e.g. max revs and speed since start up, stopwatch functions, shiftlight functions, it also removes the 180km/h JDM speed restrictor. Dunno about the RS200s you guys have but the speedo on mine reads up to 180km/h. That's cause in Japan all cars are speed restricted to this maximum. Anyway, I didn't have mine installed myself relying instead on a professional to do it for me. That's coz you wanna be able to calibrate the speedo readings to the speed readings on the SARD device. That's a bit tricky if you DIY.
Just found this on LOC , sounds like you cant fit the attack meter yourself
im gonna have a look at it my self i take it was on lexus owners club tegan
yeah thats what i said LOC
cheers just bin and looked on there no real help though thanks for finding it
be careful with boost controllers, if yoube got no idea what your doing youll blow the engine to bits
If you have a wire diagram they are a doddle to solder in (having done an AVCR, 2x SAFC's, a VAFC, an RSM, a Superchip etc. etc.).
If you can wait a while, I can take pics of my timer harness .. and I *do* have instructions somewhere.
cheers bibbs that would be a great help im in no hurry to fit them anyway
