Mk111 Brake Pads
jaydel
hi all looking for some advice does anyone know if the brake pads on a1990 mk111 2 ltr twin turbo are the same as the normal 3ltr mk 111 pads the 2ltr is an import and i cant find any info at all :(
Nope!!!!! you will notice that the 2.0 has smaller disks!!!!!!!
However, if you get a set of uk 3.0 disks, uk 3.0 pads, and uk caliper brakets it should all work together!!! As long as you have 16" rims.....
thanks for that will have to try and source some pads if not i will have to take that route
As per PM, Toyota will supply anything you need.....
