Idea Ideas!
zebidi
will another bigger car with bigger discs. if the pcd is also 100x4 will i be able to fit the discs and calipers? providing i had a plate made up for the caliper fitment?
will the offset affect anything? i always thought the offset was something to do with the hub of the wheel and wont affect the angle of the brake disc
as long as the discs fit then yes, and you get the calipers remounted
offset wont change unless the disc hub is thicker or thinner as it will physically move the wheel in/out
also as long as the disc aint too big, need to make sure the caliper clears the wheels
yay!thanks you two! been great help :D
Dont forget about the weight though,
i brought bigger up graded discs and calipers but they weighed ALOT :eek:
all weight i'd saved on the light weight wheels,was doubled by the brakes.
remember the unsprung weight rule.
you'd be better off with better discs and pads with braided hoses.
standard apart from goodridge braided hoses,
i sent the big brake kit back as it did not fit anyway,it was for the japanese vitz.
The brackets on the calipers did not line up.
Zebidi mate - much as I can see what you're trying to do - and I admire the approach, the 3G and Endless route is proven to provide a massive upgrade.
an them goodride lines are awesome
oooh an earpl your brakes rock i hammered then at top of strip thought my internal organs were cumin out
i have to say those upgrades are really good, they pull something like 1.7G, or something, from 1.1G Is that right earpl?
Remember to wear your space suit then :drool:
