Best Performance Upgrades
p11p
DOES ANY ONE KNOW THE BEST UPGRADES I CAN GET TO MAKE MY CAR A LITTLE BIT FASTER
2JZ-GTE Should do the trick..
Hope this helps.
BOB :thumbsup:
I have the same model. I bought TTE silencer, but nothing changed ;) only fuel consumption is better.
but i'm planning to remove mid silencer and put the stainless pipe from kat to that TTE silencer.
and next thing > K&N filter - this one: http://www.knfilters.com/search/product.aspx?Prod=57-0633
but I don't think it will be faster. . may be you'll get a little bit more sporty feeling, but i'm not awaiting some great performance progress .
I suggest to spent money into the lowering springs to improve the handling, and front strut bar ..
yer i might do that as i got the tte exhaust for xmas, and thats all i want, to make it sound and feel abit more sporty
you can ask G6R he removed mid silencer (he owns 1.6 I think..) so may be he could let you know whether there is some difference.
but my friend did it on E11 and he was pretty suprised :) He used the Supersprint silencer.
Here is pretty cold in slovakia, but when temperature will get over 15 I'll buy that K&N air filter. The sound should be much more nice.
You could listing here :: http://www.zippyvideos.com/9364945731647476/afbeelding_303/
thats mine with a "could engine" missing the Midsillencer but with the Cat .
and i,am planning the K&N dropinfilter with the original tube replaced for a other tube that goes to the side of my new TTE Kompressorfrontbumper , there is a opening in it . the car wil respond a little bit better than .
i a sume .
My old G6-R had the TTE frontbumper on it with a tube in one of the holes at the front and a K&N dropinfilter and that worked better than the original setup. :thumbsup:
I made it my self ;)
i a sume .
Is it difficult to change the pipe? How much does it cost for the garage to do it?
many thx
Kev
Get a 1.6. They fly compared to the 1.4!
Andy R
NONSENSE :)
i'm 1.4 owner and I had the oportunity to drive friend's 1.6 . when you're not heavy-loaded 1.4 is very good. The advantage of 1.6 is the torque. 150Nm compared to 130 of 1.4
Father has civic 1.6VTEC (better engine than rolla's 1.6vvti) and it's the same as I mentioned above - not some real big difference.
And I;m driving single, so I don't care :)
BUT doesn't matter...
G6R :: I wanted to ask you regarding the TTE compressor bumper. I saw your galley. I found it for 500euro with fog lights included, so it could be fine deal (because I don't have fog lights) to but bumper and fog lights too.
But - I have pre facelift model, so I'd have to replace front lights. . do you think it would be possible? Or I'll have to ask in the toyota service..
and one more Q:: after the removal of mid silncer, did you recognize some performance increase, or just the sound is more sporty?
;) Yes you have to replace the frontheadlights else it won,t fit . i payed € 100 for my NEW TTE Kompressorbumper including the Big T emblem Grills and Foghlights ;)
:thumbsup:
i a sume .
many thx
Kev
Take youre Battery out and take a look, messure the hole from the filterhouse and the hole through the chassis when you have the original hose out :thumbsup:
Do it youre self Kevin you can do it
100euro? waaau! :) where? I'd like to have it for that price tooo :) would it be possible?
i dont think you will need to change your headlights to fit a facelift model bumper onto a pre facelift model car! the "teardrop" on the facelift model bumper could be filled out and so will fit onto a pre faclift car without changing the headlights!!
I only mention this as I have seen a pre face lift CTS with the facelift bumper on it!!
Thats right but it eant Cheap my friend a belgium ( he sprayed my sideskirts and TTE frontbumper ) has the T-Sport Facelift frontbumper on his D4D and he filled the gap olso i will look for a picture
He wellded with plastic and than special primer
