Relocation of the plate looks better than I'd expected.
But then your car has a light color. On my black Aygo this would probably look stupid
(if it wasn't impossible due to my DRL), especially with Dutch plates being yellow front and back...
i duno i recon it would still look pretty good. get some photoshop on the blend =]
phill=]
I did. Didn't really like it, as I had to put the plate more centered than
you as I have a couple of DRL's mounted in the sytle of the TTE-grille...
I might have a look at a "square" plate though, opposed to the long rectangle...
yeah man that would look pretty cool =] try it would it be hard to fit or would you keep it in the same place as the standard one??
got any pics of your grill?? =]
Phill=]
Here's one:
Placement is based on the TTE Grille, only I mounted my lights slightly more to the center,
as I didn't want them "touching" the sides of the plastic bit like the TTE- ones do...
You can clearly see that my license plate could only be
offset for about 6 to 8", thus restricting airflow to the radiator.
I'll see if I'v got my photoshops anywhere on this computer to post them too...
Here's one:
yeah man thats pretty nice i wanted that grill but Mr t was chargeing far too much =[
yeah them pics would be gwd =]
Phill=]
  • 7 years later...
On 27 January 2006 at 4:38 PM, SMW said:
For future reference for those considering debadging their Aygo.
You will find 2 holes under each rear valence badge just below rear lights:
And the clean shaven look . . . . .
Have you left the holes?
