What is the config of the CT9 starlet turbo, I am hoping there are some CT9's that are only oil cooled (not fed with water). Is this true?
I think all the CT9's are water cooled. If you want to turbo a 5E with a CT9 you'll need a thermostat housing from a 4E-FTE Starlet turbo - this should bolt straight on.
There are other turbos which aren't water cooled, but have a different mounting pattern to the CT9.
cheer sera, where does the water return plumb to, the radiator?
They both return to the thermostat housing mate.
You will also need an oil filter re-locater from the 4EFTE as it has the oil feed on it and move the oil filter out the way of the turbo. Then you will need a sump for the oil return line.
Simon
Any one have a thermostat housing, the oil filter relocator and a MAP sensor and a knock sensor? Also looking for that crap cast downpipe thing too. One of you boys must have a shed full of starlet bits, its that sort of car. If anyone has an old CT9 that needs recon'ing or is the right money give me a shout. heres a easy to read list:-
STARLET 4EFTE BITS NEEDED
MAP SENSOR
KNOCK SENSOR
MANIFOLD
OIL FILTER RELOCATOR
CAST DOWNPIPE/CAT THING
CT9 TURBO
Can you help?
I've got a 4e-fte manifold. I've got a turbo but you wouldn't want it.
I might be getting a manifold tomorrow, what happpened to the turbo? I can get recon jobs done for the right money.
It was sawn in half by customs upon entry to the UK
WHAT??????
WTF!! Sawn in half?
The manifold I went to look at was cracked, along with the cylinder head it was attached to. But I now have the thermostat housing/water feeds.
Fancy sorting me out that manifold sera?
*****, you dont waste time do you ?! hehe
Was it intentionally sawn in half?
Did they think it was hiding some illegal contraband :eek:
I've just ordered some audio gear from the US....hope the monkeys don't need to saw that in half...
yes, they sawed it in half rendering the turbo scrap, believing it was full of drugs (it was coming in from Jamaica)
I managed to claim compensation from Customs though.
I'll dig out the manifold on Monday for you.
Did you get refunded for the drugs too?
Thanks Sera, is your name andrew?
Hi, yes - I am Andrew
They must have been looking for some 'Blow'..ahem!
Here ya go matt <---- though its in america, you must coax him into posting it to you...there's also a 4efte head on eBay usa too...
Did you dig that manifold out fella?
yep, just sent you an email
you got email
