Powering Satnav From The Cigar Lighter
Tarby777
Hi all,
I bought a Garmin Streetpilot i3 at Christmas, and all is well except for the power lead that plugs into the cigar lighter. The adaptor is quite chunky ( http://shop.garmin.com/accessory.jsp?sku=010%2D10723%2D06 ) and the gear knob gets in the way of it in 1st/3rd/5th. It's not so close that I can't engage gear, but close enough for me to get irritated at continually banging my hand into it.
Has anyone on the forum had similar probs? I'm wondering if there's maybe a different adaptor out there, without that bulbous plastic housing...
TIA
Tarby
I have a garmin street pilot 2620 and it has a large ciggy lighter speaker but has the ability to angle the speaker up towards to heater controls so I do not get this problem quite as bad as you.
The only other thing I can recommend would be to buy an adapter which allows you to plug the adapter in to the lighter socket then plug the garmin into the adapter, I am sure this will sort the problem. Ether that dismatle the adapter with speaker and hard wire it to the Battery. Whatever you do, you will need to do something a bit DIY to get round it.
Good luck!
buy one of these:
http://cgi.ebay.co.uk/Additional-Car-Cigar...1QQcmdZViewItem
then solder the wires to the back of the cigarette lighter socket
We did this. The cradle for a PDA based system suckers to the screen by the door and the cable runs down the jamb and under the dash. I then connected an extention to the back of the lighter and ran it forward exiting under the dash. Plug the two together and it look hardwired in, but can be removed in seconds without damage. Either by me of the !Removed! who decides it would look better on a pub table :( :)
also buy from maplins instead of ebay. exact same item is 99p in maplins and no waiting
Cheers for your replies everybody. Adam, I couldn't find one online at Maplins; any chance you could send a link?
TIA
Tarby
If you've got some spare cable about get this one for 99p:
http://www.maplin.co.uk/Module.aspx?Module...0socket&doy=6m2
If you want one with cable on get this one for £2.99:
and chop the plug off the end.
Personally I would go for the 99p one, and just use a bit of mains cable of similar to wire it in.
