Motec M48 Ecu For Sale
Toby
Hi all.
I have a MOTEC M48 ECU for sale, never used. Anyone who's serious about this kit will know its potential and quality. It can be used in any car. I have provided a pdf brochure for anyone wanting more information:
http://www.motec.com.au/pdf/M48.pdf
Motec M48:
"The M48 is our Engine Management System (ECU) with the ability to provide sequential injection and individual cylinder fuel/ignition trims for up to 8 cylinder engines and is designed to provide you with the power and quality of our Pro series but at lower cost by letting you option in only the features you require. It is designed primarily for performance street cars & bikes but by choosing the optional features it is perfect for competition use
Our system uses 3 Dimensional fuel & ignition mapping and ignition control to give you the ability to drive your ignition modules and set your spark timing to be at its absolute best at all points. Sequential ignition lets you fire the injectors at the optimum time in the engine cycle. Advanced tuning is an option which gives many extra features including traction control, the ability to configure the ECU to your existing sensors, etc. Another option is 512Kb of on board data logging to let you analyse the engine as it has been running. Configure the system to suit your needs and enable more options if they are required later".
More information at: http://www.motec.com.au/m48.htm
These kits are £1200 reatil exc communication lead, connector and manual (£150), im looking for £1050
(Fensport do a 1 day session to install and map - £270 or obviuosly can be mapped with the a laptop using the communication lead provided) You wont find better..
Thanks Toby. Please PM me if interested :)
